Flow does not fire with snc_read_only role
10-05-2025 11:44 PM
Hi
I created catalog item which grants snc_read_only role. Second one needs to remove role( user can request it) . I set below properties and user can create ritm while having snc_read_only but flow is not fired. How to fix it( i tested and when snr_read_only role is not present flow is fired)
Reagrds
Piotr
10-06-2025 01:15 AM
Hi
I added them and flow is not triggered
10-06-2025 01:07 AM
Did you try running flow with System user and see?
10-06-2025 01:15 AM
Hi
yes it is set like this, but it does not work
10-06-2025 01:39 AM
flow is not fired?
what does this mean?
Is your REQ marked as approved?
If yes then only RITM flow will kick.
10-06-2025 04:34 AM
Hi
It is not marked approved. The statusis: Pending Approval Request and there is no show context in related links where i am able to look into flow.
