Flow not retrieving Output value from Flow Action
Markell
Hi Guys
I have an issue with Flow Designer where by I created an action within a flow.
I know the Action is receiving the correct input values as they show on the Step Configuration when I test:
I know that in my Action the script is working and producing the outputs that I need when I test the action
But what is not working is that when I run the test on the overall flow (which is meant to use the output values to send an email) the flow execution reads that the "Email has no recipients".
When I look at the outputs in the flow execution for my action, in this instance there are no outputs:
Can anyone point me in the right direction as to why the Action will display correct info when I test the action but when I test the overall flow that the action is in, then the Outputs cannot be retrieved?
Kind Regards
Markell
Markell
Hi Guys so got this sorted with SN Support. They advised that the issue doesn't seem to be a problem with the input data, but does appear to be a known new bug, discovered recently on a previous case, and referred me to this knowledge article.
The fix was to change part of my code to retrieve the input value from:
var value = inputs.request_item;
grReq.addQuery('sys_id',value.);
to
grReq.addQuery('sys_id',value.getUniqueValue());
"It seems to be an issue how the Reference is passed to the subflow as input."
Posting this in the hope it helps someone else in future as I did not know you had to use getUniqueValue() to get the sys_id to pass the value in a flow (and that this was a previously known issue).
Markell
Markell
to
Markell
