g_form.addInfoMessage and errorMessage does not work in Workspace
PrakashRam
Hi Team,
I have configured a client script which shows info message and error message on native UI and does not show in Workspace. Any Idea?
I was suspecting that as it is asynchronous call, it does not wait for the call to complete and it skips the getResponse() function.
Any Idea is appreciated.
@Ankur Bawiskar : Please share your valuable responses.
function onLoad() {
    if (g_form.getDisplayBox('recovery_time_objective').value != '') {
        var ga = new GlideAjax('sn_bia.BIAEngine'); //Scriptinclude
        ga.addParam('sysparm_name', 'conflictRTO'); //Method
        ga.addParam('bpSysid', g_form.getUniqueValue()); //Parameters
        ga.addParam('bpRTO', g_form.getDisplayBox('recovery_time_objective').value);
        ga.getXMLAnswer(getResponse);
    function getResponse(response) {
        var res = JSON.parse(response);
        if (res > 1) {
            g_form.addErrorMessage('You have ' + res + ' dependent Business Process having Higher RTO.');
            g_form.showFieldMsg('recovery_time_objective', 'The Estimated RTO conflicts to its more than one dependent Business Process. Please review it before you create a plan.', 'error');
        if (res == 1) {
            g_form.addErrorMessage('You have one dependent Business Process having Higher RTO.');
            g_form.showFieldMsg('recovery_time_objective', 'The Estimated RTO conflicts with one of its dependent Business Process. Please review it before you create a plan.', 'error');
Hi Prasad,
You are correct. Even I suspected the same. But the line setCallback is not working.
I have replaced with your code. It doesnt work. May be setCallback method id deprecated method.
Any idea is appreciated.
Thanks.
I can't get an errorMessage to not show in workspace onLoad.  In the browser developer tools are you getting any related console errors?  What does your Script Include look like?
Tai Vu
Hi @PrakashRam
getDisplayBox will not work in Workspace. Inspect and open the Browser Console, you should see the error message.
If you'd like to retrieve the display value of a reference field in workspace, try to use getDisplayValue instead.
Or you can simply pass the field value and handle next steps in the conflictRTO function.
Cheers,
Tai Vu
