Help in my code
05-06-2024 12:32 PM
I'm trying to create a code where, every time a ticket is created, the queue field is updated, and as it's going to be a lot, I thought about creating a client script instead of using flow, + I'm not able to change the queue field
// Client Script to direct a ticket to a queue based on the fields filled in the catalog tree
function onSubmit() {
var area = g_form.getValue('area');
var system = g_form.getValue('system');
var serviceType = g_form.getValue('service_type');
// Determine the queue based on the field values
var queueValue = determineQueue(area, system, serviceType);
// Update the 'Queue' field with the correct value
g_form.setValue('queue', queueValue);
// Function to determine the queue value based on the field values
function determineQueue(area, system, serviceType) {
// If the area is TI, the system is "app", and the service type meets the criteria
if (area === 'ti' && system === 'app' &&
(serviceType === 'maintenance_ti' || serviceType === 'installation_ti' ||
serviceType === 'configuration_ti' || serviceType === 'customization_ti')) {
return 'app_n1'; // Queue value for app_n1
// If no case matches, do not return anything
return ''; // Returns an empty string when no case matches
if the area field is 'ti' and if the system field is 'app' what if the service_typer field is any of: malntenance_ti, installation_ti, configuration_ti, customizetlon_ti, the queue value must be app_n1
05-06-2024 01:00 PM
Seems 'queue' is a choice field, in that case you need to verify 'app_n1' is a valid value. You can also an "alert('determineQueue is returning app_n1');" inside the 'if' statement to see if the condition passes. Add "alert('area = ' + area);" lines to verify the values used in the if condition.
05-06-2024 01:09 PM
I didn't understand how to do this, and now I have another question, I created the script using Studio's ClientScript, this script would be using the Client or Flow?
05-06-2024 05:31 PM
Try the following in your code, as you test, you will see the results of the debug:
alert("Set queue = " + queueValue);
alert('Checking queue value: area = ' + area + ', system = ' + system + ', serviceType = ' + serviceType);
var cond = area === 'ti' && system === 'app' &&
serviceType === 'configuration_ti' || serviceType === 'customization_ti');
alert('Checking queue value: condition = ' + cond);
alert('Checking queue value: returning app_nl');
05-07-2024 06:00 AM
It shows alerts about what is happening, but when I finish creating the ticket and go to the support view, the queue value does not change and remains NONE
05-07-2024 06:23 AM
Check for ACLs, dictionary overrides, and/or business rules that prevent updating the 'queue' field.
