Help me with Script include , it's returning null
client script
var user = g_form.getValue('requested_by');
alert(user);
var ga = new GlideAjax('paccount');
ga.addParam('sysparm_name','getAccount');
ga.addParam('sysparm_user', user);
ga.getXML(classdemo);
function classdemo(response) {
alert(answer);
g_form.setValue('project_account', answer);
script include
var paccount = Class.create();
paccount.prototype = Object.extendsObject(global.AbstractAjaxProcessor, {
getAccount: function() {
var value = this.getParameter("sysparm_user");
gs.info("PA" + sysid);
var accountname = "";
var gr = new GlideRecord('x_800355_corpora_0_employee');
gs.info("Hello" + gr);
gr.addQuery('sys_id', value);
if (gr.next()) {
gs.log("hello" + gr.project_account);
accountname = gr.getValue(project_account);
return accountname;
//return accountname.getDisplayValue();
type: 'paccount'
9 REPLIES 9
Hi @Community Alums,
Please validate that you are calling exact backend name project_account. And also validate you are getting sys in of user in client side and try to get other field value.
Jitendra
Hi @Community Alums ,
I checked your script there is one small error please use below script
if (gr.next()) {
accountname = gr.getValue("project_account"); // Please add string in project_account
Please mark my answer correct and helpful if this works for you
Thanks and Regards
Sarthak
@Community Alums  even i was able to pull value in background script ,  not sure why it is not working here @Jitendra Diwak1  even logs are not coming
Please find below screen shots and guide me
VijayKummamuru_0-1718284329533.pngVijayKummamuru_1-1718284362092.pngVijayKummamuru_2-1718284570404.pngVijayKummamuru_3-1718284599468.png
Hi @Community Alums  The script include is failing at line 6  at gs.info("PA"+sysid ) as you kept sysid (which is not defined in code ) .
Please remove line 6 info log (or) instead of using sysid use value and test the code . you will recieve all logs and code will work.
Here I am providing script to Auto Populate Callers Manager on Incident Form , you may follow the script to achieve your requirement.
Attaching screenshots for reference.
1.Client Script
2.Script Include
3.Output on Incident form.
Please mark my response as correct and helpful if it helped solved your question.
Rohit Suryawanshi
