Help on flow designer
William08
Hi all,
Need a help on flow designer. In a item there is variable and its a single line text so when we submit the request based on the number of values entered it should create task and after all tasks are closed it should close ritm.
For example lets call the variable as test and this variable as value 1,6,5,4 so there are 4 values entered so it should created a 4 task.
Thanks in advance
Sonam Tiwari
@William08 ,
Till here, I don't find any issues then
Can you please provide the screenshots of further actions in the flow? Will try to see if something went wrong in next steps.
Sonam Tiwari
@William08 ,
@Sonam Tiwari
It's strange it was throwing error yesterday but when i tried now it's working Many more thanks to you it is working perfectly.
Thank you
