Help on regex for phone number format XXX-XXX-XXXX
dianeramos
We have a requirement to have a standard format for the phone number field to be XXX-XXX-XXXX (with hyphens). Do you have any suggestions how i can achieve this by validation regex?
Thank you in advance
Brad Bowman
Mega Patron
Hi Diane,
We use this Regular Expression in a Variable Validation Regex for US Phone Numbers.
^\(?([0-9]{3})\)?[-]([0-9]{3})[-]([0-9]{4})$
himanjaiswal
Try Below Code to convert Phone Number in xxx-xxx-xxxx
var pattern = /[^a-zA-Z0-9]/g;
        var cleanPhoneNum = phoneNum.replace(pattern, "");
        var formatPhn = cleanPhoneNum.substring(0,3)+"-"+cleanPhoneNum.substring(3,6)+"-"+cleanPhoneNum.substring(6,11);
Please mark correct if you find the above solution helpful. 🙂
