Help! Reference qualifier to show only with 5 digit numbers
Jet R
Hi!
We have a custom field in the Department Tablen called "department id"  where in the data contains 5- 7 digit numbers.
Now in the record producer field we only want to show the records with only 6 digits.  How can I achieve that? Thanks
Eg. Let say in the table below we only need to show in the record producer field the records Accounting and IT.
Department Name Department ID
HR 01203
Accounting 123456
Fleet 0234858
IT 033332
Hi @Jet R
Thanks for marking my reply as Helpful.
If it ends up guiding you Correctly, please also mark it as Correct.
Thanks and take care! 🙂
