Help Required in changing images in Service portal
GaneshErike
In Service Portal of our project have images, like when we click on "Home", there are images that are appearing,
They will be scrolling horizontally from right to left. The images appear one after the other in a continuous sequence.
I need to update those images.
Please assist me in updating images.
Thanks in advance.
Navigate to Service Portal > Service Portal Configuration > Designer locate your portal + page and click on the pencil icon for the container
Check this KB:
https://support.servicenow.com/kb?id=kb_article_view&sysparm_article=KB0754937
Hello @GaneshErike
Please refer this document for the steps to change the images.
Hope this helps!
"If you found my answer helpful, please like and mark it as an "accepted solution". It helps future readers to locate the solution easily and supports the community!"
Thank You
Juhi Poddar
Thank You!
Juhi Poddar
