Help required with Script for Transform Map
Jason Nicholas
Hi
I have a transform map that without the script does the following after importing all project tasks via a spreadsheet:
Source.u_line_unique_key > Target.u_unique_ref (Coalesce)
Source.u_start_date > Target.start_date
Source.u_end_date > Target.end_date
As part of the mapping I have the following script, what I am trying to achieve is
  • Where the Project Task is NOT in a pending (-5) state ignore altogether
  • If the Task state is pending (-5) then clear the date field
  • However if the Task state is Pending AND the u_set_date on the task is marked as is true then set the dates (I will eventually want it to set it to leave the dates as they are)
I have tried every which way to configure that I can think of but it either
  • Updates all tasks based on the spreadsheet dates
  • Clears all dates on every project
  • Does nothing
Can anyone advise please
(function transformRow(source, target, map, log, isUpdate) {
    var PTask = new GlideRecord('pm_project_task');
    //  PTask.addQuery('u_set_dates', true);
        PTask.addQuery('state', -5);
        PTask.query();
while(PTask.next()){
        if (PTask.u_set_dates == 'true'){
            target.start_date = '01/01/2025';
            target.end_date = '02/01/2025';
            gs.log('wxy: project found ' + PTask.number + '- ' + target.start_date + ' - ' + target.end_date);
        //  ignore=true;
            target.end_date = '';
            target.start_date = '';
        //  ignore=false;
})(source, target, map, log, action==="update");
Awesome! Sounds like just a small adjustment and you should be there! Let me know if you have any other questions or issues.
