Help Transform Field map script not working correctly
E_19
Giga Expert
I hope someone can help me.
I have a transform field map script that is not working correct. What I am trying to do is iterate though the source kunden number and for all matches that are found in core company table   the corresponding sys_id is added to u_company field but the script iterates and has the same company sys id for every record. In the log file it records same sys_id but also each unique kunden number.
Need to add the field is a reference field and the Referenced value field name: u_company
Any idea why it is not return the unique sys_id for each record?
answer = (function transformEntry(source) {
  var gr1 = new GlideRecord("core_company");
  gr1.addQuery("u_company",source.u_kundennr_.toString());
  gr1.query();
  if(gr1.next()){
  target.u_company = gr1.sys_id;
  gs.log("Kundennummer: " + source.u_kundennr_);
  gs.log("sys_id von ?: " + gr1.sys_id);
  return ""; // return the value to be put into the target field
})(source);
Many Thanks,
Ellie
can you try like this
  gr1.addQuery("nr",source.u_kundennr_.toString());
  gr1.query();
  if(gr1.next()){
// put your logs here
E_19
Giga Expert
All,
I want to add something but I might open a separate post.
The load will be a scheduled nightly load using the updated source file.
If users are removed form the file I need to set their records to u_active = false.
How can I compare the load and find the records that are missing to what is currently in the table?
Any suggestion or code sample welcome
Many Thanks,
Ellie
