Help with a script to set assigned to based on assignment group changing and Location
carlh
I was asked to make a pretty simple business rule but it turns out I need to script in order to get it to work.
Could anyone help me with the following?   (Don't worry, we just hired a resource and I will be sharing this as an example so we can write our own soon)
I have added a field to our LOCATIONS table (cmn_location) called "Stock Control".   It's a reference field to users.   The plan is to use the field to assign hardware requests when the Assignment group is changed to "Stock Control".
Here's the pseudo script on the REQUEST TABLE.
Before
Insert/Update
IF 'Assignment Group' changes to "ITSM - StockRoom", Set the "Assigned to" to Same as 'location.u_stock_control_ref'
Please help if you can.
Thank you,
Carl
Pradeep Sharma
Hello Carl,
Create the Before business rule with filter condition i.e assignment group | changes to | ITSM - StockRoom with scripts as
// Add your code here
current.assigned_to = current.location.u_stock_control_ref;
})(current, previous);
9 REPLIES 9
This is working but the asset manager asked if I could clear the assigned to when it changes back.
So if Assignment Group is Stock Room, and it changes to Purchasing, I want the assigned to be cleared
Pradeep Sharma
Yes, you can do this as
if(current.assignment_group.changesTo('ITSM - StockRoom')) //Assuming ITSM - StockRoom is the group name
else
current.assigned_to = '';
This wouldn't be specific to logs changing from "ITSM - StockRoom" to *something else*.
The 'assigned_to' will be cleared, if the assignment group changes, on all records in the table that has this business rule.
You are right Lee. We need to define condition filter to trigger this BR only when Assignment group | Changes to | ITSM- StockRoom OR Assignment group | Changes From | ITSM_ StockRoom.
Thanks to all who replied.   Pradeep was able to send me something I could use right away so he get's the correct answer!
