Help with Client script When a Particular Configuration Item is choosen
Shree Nag
I have a requirement to make a state value( "Work In Progress" )  visible only when a particular configuration item is chosen on an incident form.
If a user choses "Abc" in configuration item on an incident form, Work In progress state ( value =-5) value should show up in State field.
Can you all help me with the client script for this please.
Appreciate your response.
-Thanks
Shree
Hi @Shree Nag
Can you try the below script
    // If the form is loading or the new value is empty, do nothing
    if (isLoading) {
        var citem = g_form.getValue('cmdb_ci');
    var citem = g_form.getDisplayBox('cmdb_ci').value;
    alert(citem);
    if (citem !== '' && citem.startsWith('Thi')) { // updated the code as per your need
        g_form.addOption('state', 'work_in_progress', 'Work In Progress');
        g_form.removeOption('state', 'work_in_progress');
Thanks and Regards
Sai Venkatesh
24 REPLIES 24
Ahh ! Now with the latest script updated, Thank you.
It shows Work in progress for any configuration item selected.
If the configuration is empty, work in progress not seen.
I need to add in the script, If the Configuration Item contains anything starting with "ABC", show work in Progress.
Hi @Shree Nag
    if (isLoading) {
    alert(citem);
Thanks and Regards
Sai Venkatesh
Hello Sai,
That worked perfect!!! Thanks for continuous help !.
Appreciate it .
Deepak Shaerma
Hi @Shree Nag
Try below script and modify it according to your correct values.
var stateField = ‘state’; // Reference to the state field
    var workInProgressValue = ‘-5’; // The value corresponding to “Work In Progress”
    // Check if the configuration item has a value
    if (newValue) {
        // Add “Work In Progress” option if it’s not already there
        if (!g_form.getOption(workInProgressValue)) {
            g_form.addOption(stateField, workInProgressValue, ‘Work in Progress’);
        // Remove “Work In Progress” choice if the CI field is empty
        g_form.removeOption(stateField, workInProgressValue);
        // Ensure that the state field is cleared if it holds the “Work In Progress” value
        if (g_form.getValue(stateField) == workInProgressValue) {
            g_form.setValue(stateField, ‘’);
please mark this Helpful and Accepted Solution if this helps you. Your action will help me and the community in understanding same requirements.
Thanks & Regards
Deepak Sharma
Madankumar N1
function onChange(control, oldValue, newValue, isLoading, isTemplate) {
    if ( newValue === '') {
   var configurationItem=g_form.getValue("configuration_item");
var state=g_form.getValue("state");
if(state!="work_in_progress"){
    if (configurationItem == 'cisysid') {
        g_form.addOption('state''work_in_progress''Work In Progress');
    else{
          g_form.remove('state''work_in_progress''Work In Progress');
Make Sure your using choice value of State Work in Progress while adding choice and removing
