Help with Cross-Domain Approval
mandalorian
Hi everyone,
I’m seeking help with an issue we're facing after implementing domain separation in our instance. Here's the situation:
Issue:
We have a workflow that involves a group approval step. The workflow is designed to continue once one group member approves the request, and the remaining approvals are marked as "no longer required." This setup was working well until we enabled domain separation plugin for requested items.
Members of the approval group belong to two different domains:
- Domain A: 3 members
- Domain B: 4 members
The approval process typically happens in Domain B, but in some cases, we want Domain A members to be able to approve the request on behalf of Domain B members. Both domains fall under the TOP domain.
Since enabling the domain separation plugin, the workflow no longer recognizes Domain A members’ approvals for requests that are initiated in Domain B. The workflow stalls, as it doesn’t acknowledge the approval from Domain A.
What I've Tried:
I've explored different solutions, including some that suggested using common domain for 2 domains to grant cross-domain approval permissions, but none of them worked due to domain restrictions enforced by the plugin. Maybe I am missing something in the process.
Question:
Could anyone guide me on how to configure the system (maybe through ACLs or another method) so that members from Domain A can approve requests for  Domain B  and allow the workflow to proceed smoothly?
Any help or suggestions would be greatly appreciated! This is my first post, and I'm excited to hear from the ServiceNow community of experts and enthusiasts.
Thank you in advance!
mandalorian
Hi Everyone,
I wanted to share a solution I found for handling cross-domain approvals in ServiceNow when the domain separation plugin is enabled.
Here's what I did:
1. I used Flow Designer to create a flow.
2. The flow is triggered by the sysapproval_approver table with specific conditions for update.
3. It then looks up the related sysapproval_group record.
4. If step 3 is successful, the sysapproval_group record's approval state is updated to 'approved'.
4. I set the flow on the global domain, which has access to the top and its related domains.
I hope this post will be helpful to anyone facing similar issues with cross-domain approvals.
Thanks and cheers,
Mando
mandalorian
Hi Everyone,
Here's what I did:
Thanks and cheers,
Mando
