Help with for loop
harishdasari
I am writing a script, where it will have numbers something like this below
var string = 69,110,103,108,101,119,111,111,100,67,111,108,111,114,97,100,111,56,48,49,49,50,85,83,65;
SUM = 2236;
Length of the above numbers are 25
If we divide sum with length 2236/25 = 89.44 this is the average I am getting.
Now requirement is I want to subtract(minus) average from each of the number.
for example: if we minus 69-89.44 = -20.44, similarly 110-89.44 =20.56
I want to loop through all the numbers and minus with the average.
I am using for loop, but it is giving me some wrong results.
Thank you.
Alikutty A
Tera Sage
Please try this out in background
var list = [];
var locationOnincidentForm = "Englewood Colorado 80112 USA";
var WH = locationOnincidentForm.replace(/-|\s/g,"");
var str = WH.replace(/\s/g,'');
var total= 0;
var numArr = [];
for (var i = 0; i < str.length; i++)
total  += str.charCodeAt(i);
var average = total/str.length;
gs.print('Total   ' + total);
gs.print('Average ' + average );
gs.print(str);
var minus = str.charCodeAt(i)-average;
gs.print(minus);
list.push(minus);
gs.print(list.join(","));
Thank you so Much , it worked.
