03-21-2025 08:11 AM - edited 03-21-2025 08:12 AM
I need assistance understanding how lookups work in Flow Designer.
Essentially, I need to:
1. Look up all the account records where "status" is "open"
2. For each of those accounts, lookup all "general cases" records where "active" is true and "account" matches each of the accounts found in the previous lookup.
3. If "status" of lookup in step 2 is "Success" (ie there are active cases associated with any of the accounts), then update all the cases associated with each account returned and update the work notes with any comments.
4. If "status" of lookup in step 2 is "error" (ie no active cases), then perform another lookup on the customer_contact table for each of the accounts from step 1 to see if there's a contact associated with the returned accounts.
5. If "status" lookup in step 4 is "success" (ie there is a contact), do nothing.
6. If "status" lookup in step 4 is "error" (ie there is no contact), then create a new general case for each of the accounts returned.
Thank you in advance
03-21-2025 09:19 AM
this should help.
I believe I have answered your question and you can take it from here
03-21-2025 09:10 AM - edited 03-21-2025 09:14 AM
Hi @Ankur Bawiskar thanks for sharing this, are you able to expand every step 4 -6 -7 -9 - 10- 11 so I can see the condition you applied and then test mine? Thank you
03-21-2025 09:19 AM
this should help.
03-21-2025 09:40 AM
@Ankur Bawiskar thank you very kind. I'll test and let you know.
03-21-2025 09:55 AM
It worked, thank you so much!!!
03-21-2025 09:05 AM
Hi @Snowman15
It is doable, but it would be better if you try it yourself.
Instead of going directly into ServiceNow, try creating the flow on paper first. This will make it easier for you to visualize where to add each part.
Flow Designer Action: Look up records
Flow Logic: For Each
Action: Create/Update record.
