Help with OnLoad Client Script with Currency Field
jlaue
Hello -
I am working on an OnLoad client script that checks a currency field, and if it is the default of '0.00' I want to set the background color of the field on the form to red.  I have checked around community and found some examples and based on that, I have this script, however it is not working.  I was wondering if anyone could provide some guidance on this.  I realize that I can use a Field Style, but I only want the background to be red if there hasn't been a value entered in there, so anything other than 0.00 in the currency field.
function onLoad() {
    var element = g_form.getElement('base_rent_per_month');
    var value = g_form.getValue('base_rent_per_month');
    if (value == 'USD;0.00') {
        element.style.backgroundColor = "red";
I have also tried different value combinations like:  '0'   '0.00'   ''   'USD;0'
Thanks!
Appreciated that you have pointed towards one of the possible cons of using hardcoded value which might change for different languages.
I hope so that g_form.getDecimalValue() pointed by you in your answer, will also work for values like you have specified "USD;0,00", or for any other possible value which does not contain dot(.) to distinguish decimal part of a number.
@jlaue  consider using this better version of above script.
	var display = g_form.getControl('<your_table_name>.<your_field_name>.display');
	var currency= g_form.getControl('<your_table_name>.<your_field_name>.currency');
	if(g_form.getDecimalValue('<your_field_name>') == 0){
		display.style.background = 'red';
		currency.style.background = 'red';
	else{
		display.style.background = 'white';
		currency.style.background = 'white';
	else{
Thank you all for the responses and input.  The OnChange client script provided by @Muhammad Khan  worked perfectly and is an even better solution than what I was looking at.  The ServiceNow community is truly the greatest !!
It does, that is why I suggested it 🙂
