Help with script for advanced reference qualifier
04-17-2024 06:48 PM
Hi Community,
The last current.variables works fine. (+'assigned_to=' + current.variables.tb_submitted_for;) no issues
But, 'sys_idNOT LIKEcurrent.variables.first_list_of_assets^' is not working. - no errors
javascript&colon'install_statusNOT IN7,8,17,^'+'model_categoryNOT LIKEServer^'+'sys_idNOT LIKEcurrent.variables.first_list_of_assets^'+'assigned_to=' + current.variables.tb_submitted_for;
The value in the first_list_of_assets field is a list of Sys IDs separated by a comma.
04-17-2024 07:21 PM
Hi @Lon Landry4 ,
Please use the updated one as below.
'sys_idNOT LIKE'+current.variables.first_list_of_assets^
avascript&colon'install_statusNOT IN7,8,17,^'+'model_categoryNOT LIKEServer^'+'sys_idNOT LIKE'+current.variables.first_list_of_assets^'+'assigned_to=' + current.variables.tb_submitted_for;
-Thanks,
AshishKM
04-18-2024 05:39 AM
I tried that syntax earlier -'sys_idNOT LIKE'+current.variables.first_list_of_assets^
but the filter stops working completely.
04-18-2024 06:21 AM
please see attachment further down in chain for code example
04-17-2024 07:29 PM
Hi @Lon Landry4,
Try this -
javascript: 'install_statusNOT IN7,8,17^model_categoryNOT LIKEServer^sys_idNOT IN' + current.variables.first_list_of_assets + '^assigned_to=' + current.variables.tb_submitted_for;
Sagar Pagar
