Help with setting Max Rows in multi row variable set
nicolemccray
I've tried setting a max limit in the individual variable attributes, but it is allowing more than 10 entries.  What am I doing wrong?:
Mark Roethof
Hi there,
Use the attributes field on the multi row variable set itself instead.
Kind regards,
Mark
2020 ServiceNow Community MVP
2020 ServiceNow Developer MVP
LinkedIn
Kind regards,
Mark Roethof
10x ServiceNow MVP
LinkedIn
Mark Roethof
Hi there,
Kind regards,
Mark
LinkedIn
Kind regards,
Mark Roethof
10x ServiceNow MVP
LinkedIn
I don't see that field as an option?:
Are you on the New York release? If so the field should be available. Maybe it's just not on your form? Can you check the XML or Configure form lay-out, is the "Variable Set Attributes" field available?
Kind regards,
Mark
LinkedIn
Kind regards,
Mark Roethof
10x ServiceNow MVP
LinkedIn
Never mind, found it.
