Help with transform field map script
Snowman15
Giga Guru
Hi all,
I am struggling with a field map script, and could use some guidance from the community.
Due to limitations, the source spreadsheet columns cannot be modified, so I need to handle everything via scripting.
One of the source fields, source.u_softwaretype, contains values formatted like:
"GH001 - Software Not found"
What I need to do is:
  1. Extract just the code portion ("GH001") from the text.
  2. Perform a lookup in the x_software_list_code_mapping table where:
    • supplier = 'WILLIAMS'
    • code = 'GH001' (the extracted value)
  3. From the matched record, retrieve the serial_number field value.
  4. Populate the target reference field with that serial_number field value.
This is the script I tried so far but is not working:
(function transformEntry(source) {
var match = source.u_softwaretype.match(/(GH\d{3})/);
if (!match) return "";
var extractedCode = match[1];
var gr = new GlideRecord('x_software_list_code_mapping');
gr.addQuery('supplier', 'WILLIAMS');
gr.addQuery('code', extractedCode);
gr.setLimit(1);
if (gr.next()) {
return gr.serial_number;
return "";
})(source);
Thank you
Muhammad Salar
Tera Sage
Hello @Snowman15 , try this,
gr.addQuery('code', extractedCode.toString());
