11-03-2023 01:50 PM
Hi everyone,
I have a LDAP transform map to insert/update User records from AD. I need help with a script to not update Samaccountname field when the user is terminated (it may update any other fields if the user is terminated except Samaccountname). Please provide and ideas or script to acheive this scenario.
Thank you in advance,
Karthik
11-06-2023 09:03 PM
Hello @Karthikpasikant
Please change the field mapping for Samaccountname to Script type like the one shown in below screenshot and use the script provided. If you have any different field names or logic to determine terminated accounts change the script accordingly.
answer = (function transformEntry(source, target, action) {
if (action === 'update') {
var ctrl = parseInt(source.u_useraccountcontrol, 10);
ctrl = ctrl.toString(16);
//Check if the user is terminated/disabled, if Yes, don not change the samaccount name
if (source.u_useraccountcontrol == '514' || ctrl.substr(-1) == "2") { //Generally this is how we identify terminated accounts, if you have any other conditions/logic you can use the same here.
return target.u_samaccountname;
return source.u_samaccountname;
})(source, target, action);
Please mark my answer helpful and accept as solution if it helped you ✔️👍
11-06-2023 09:03 PM
11-07-2023 11:59 AM
Hi Anvesh,
I will give a try with the code you posted and will update this post soon.
Karthik
11-07-2023 06:02 PM
@Karthikpasikant Have you tried this code?
As you said you can use u_extensionattribute6 field also to determine if the user is terminated or not in the above code.
11-08-2023 09:23 AM
Hi Anvesh,
I have used your code and modified with our attributes. It worked great. Thank you for all your help.
Here is my code.
answer = (function transformEntry(source) {
var empStatus = source.u_extensionattribute6;
if (empStatus == "Terminated" || empStatus == "Disabled") {
return "";
})(source);
11-05-2023 08:59 PM
Hi Karthik,
Is the terminated user pulled from same OU as that of Active user from AD?
