How do I Call a workflow from Flow Designer?
Nani6
Mega Guru
I have a requirement to call a workflow from a flow designer. I tried using the OOB Flow Logic "Call a workflow" but the issue is that the workflow created on Requested Item are not visible under this list.
Can anybody help me with creating a new action to call a workflow?
Any help would be greatly appreciable.
Thanks in Advance.
There is another thing to take into consideration.
If you would create a custom action, that starts a Workflow, as far as I know, you have no point of reference in the Flow to know when the workflow has been completed.
Compare to the OOB action "Start a Workflow", that has a "Wait" checkbox, (and the same goes for the start a Subflow action also).
So your Flow might finish, and the workflow can continue running long after the Flow is completed.
I don't know if that would be an issue.
Take a look into below video for creating custom action.
https://community.servicenow.com/community?id=community_video&sys_id=b810b0a81b4185901e579979b04bcb32
Sachin
