How does the oob procurement process flow work?
rev3
Mega Expert
I turned on the procurement plugin. "com.snc.procurement" and loaded the demo data.
I am trying to test how "procurement process flow- Hardware" workflow works. So i tried to request "Microsoft Wired Keyboard" in the demo instance. But looks like the workflow is stuck where it says waiting for the items to be sourced.
I also looked into the "Source Request" workflow but that does not do anything.
I am sure i must be missing something important here but i am unable to find it.
Thank You
model field in your product catalog item should be filled.
Did you create your product catalog from a Hardware model. If yes, it will work.
I used the oob item i did not create that from product catalog.
Thank You Sanjiv for guidance. I understood the process.
