How to add help text to Multi row variable set
08-21-2020 05:18 AM
Hi
How to set Help text ("More Information") for a Multi row Variable set in Catalog Item?
I am able to do the same at individual variable, but I wanted to set the Variable set Level.
- 10,833 Views
08-21-2020 05:54 AM
I dont see that on the form layout too 😞
do we need install anything ?
On the multi row variable set i went to configure form layout when i search for variable set attribute i dont find that
08-21-2020 05:59 AM
Hi Irfan,
As updated in comments it is not available on form view OOB.
You can add it to the form view by Configuring form fields
OR
Edit it directly from list view.
08-21-2020 06:00 AM
We are still in Madrid and i think that comes from New york version 😞
Is there any other way we can limit the rows to 10 ?
08-21-2020 06:01 AM
You can use scripting to do so. But would not recommend, since Paris is out an upgrade of your instance can't be far away.
08-21-2020 06:00 AM
