How to add "Add to Cart" in Order Guide
keerthisr
How to add "Ad to Cart " i order guide .My rquiremetn is "When we use order guide in portal needs to enable "Add to Cart" in each item.
As of now its coming as "Submit" button instead can we enable add to cart button?
Anyone has any idea.
Hi Harsh Vardhan,
It seems that Jakatha latest version. Is that possible in Istanbul?
This functionality is available from Jakarta only.
ok thanks priyadharshini. But is there any way we can add in the istanbul version.
When we use order guide the option should needs to come.
yes. generally it automatically comes if in case you are not able to see then manually you can do it.
try with above link.
Enable the Shopping Cart widget
Yes . But its coming only when we raise single catalog item. Instead when we use Order guide to raise a request the option is hidden . Only submit available as per my above screen shot. There I am expecting to enable Add to Cart. Not sure that is possible or not.
