How to add tasks created by flow designer to HR case embedded list?
Pavani131
I have created a flow which works as--whenever a case is created for a service the tasks should trigger and should be added on that Case automatically when the trigger conditions are met.
The  tasks are not getting added to the Case unless a 'test' is run on the flow.
Any suggestions on how to solve this issue.
Thanks in advance.
Sandeep Rajput
Ah, I faced the similar scenario in the past when the flow was not triggering on creation of a record. This look like an issue from ServiceNow when the flow doesn't trigger on the record creation on its own.
In order to fix this, I simply created a business rule which triggered the flow for me.
To trigger the flow via business rule follow the following steps.
1. First open the flow in the flow designer which you would like to trigger via the code. Open the more tab and click on Create code snippet
2. This will take you to a page where the code to call the flow is shown.
This is how you should configure your business rule.
Here is how you should configure the script field.
Once done, try creating a new case of the Direct Deposit Inquiry Service and this time the flow will get triggered for sure.
Hope this helps.
Glad it helped 🙂
