How to ask Parallel Approvals using Flow Designer
surajsironi
ITSM checked them approavls has to go ITSM group
ITOM checked then Approvals has to go ITOM group
if All 3 Selected approavls to go respective groups and must take approavls each respective group member.
based on checked box selection approavls has to go respective groups and create TASK asfter approavls.
I tried "Do the following in parallel" Problem with this,:
When ITSM group members approved from thier side automatically system moving forward for ITOM and HRSD also , ITOM /HRSD group approavls state changed to 'No Longer Required'  , why it is happeing like that ? if ITSM approver approves means ITSM loop only go farward, ITOM approver not made decision yet so has to be waited for ITOM approval right .
So How to send Approvals Prallally based on Checked boxes selection and Take approval decision Independantly for each check box  from respective thier own group and move Independantly as per decision made by respective group members.
in document they are suggesting to create TASK, means I have to create 3-CAtalog task for each check-box ?
no other way ?
@surajsironi
check 1st link where some workaround is given.
