How to avoid using for each in flow designer ?
kiran kumar m1
image (9).pngimage (8).pngimage (7).pngI have a catalog in which , multiple users request a software or single user requests multiple softwares ,
in the flow i want a managers approval , if suppose three users were selected , then it should create three manager approvals , for which i did the lookup in sys_user table , there in the condition I have written a script
"var uid=fd_data._1__get_catalog_variables.requested_for2;
var query = "sys_idIN" + uid;
return query;"
this script will fetch the sys_ids from the list collector type variable , then I have written a for each which will take each sys_id and it will create  a approval record for it
once this approvals are created , when each approval is approved I want a task should be created ,
but here as I am using for each , its picking a random sys_id / picking in ascending order ,
until and unless i approve the approvals in order the next task generation is not happening as expected is there any way I can overcome this
Ehab Pilloor
@kiran kumar m1
Try single Approval action, use rule as All Users Approve or Reject, code the logic in Rules based on sys ids you have collected.
Please Accept this response as Solution if it assisted you with your question & Mark this response as Helpful.
Kind Regards,
Ehab Pilloor
yashkamde
Hello @kiran kumar m1 ,
If you want to achieve parallel approval then have a look on this approach :
How to ask for approval in parallel using Flow designer from a list collector
