How to Call Script Include from Catalog Client Script
Y_O
Mega Expert
Hi Community,
I'm trying to call a script include from a catalog client script, but it doesn't work.
Some trials to investigate the cause and the results:
1. I changed the contents of the scripts to something very simple to investigate the cause, but the result is not returned.
2. I'm trying to spit out logs in the script include, but I don't see any logs. (Other script includes display the log, so you don't need to troubleshoot that part.)
3. The catalog client script itself is working fine, and "g_form.addInfoMessage" shows that null is returned from the script include.
Can anyone tell me what's wrong or detailed troubleshooting steps?
The following are the set values:
<Catalog Client Scripts>
    Applies to: A Catalog Item
    Active: True
    UI Type: Mobile / Service Portal (The result is the same even if it is All)
    Application: Global
    Type: onChange
    Applies on a Catalog Item view: True
<Script Include>
    Application: Global
    Accessible from: All application scopes
    Client callable: True
    Active: True
    Protection policy: None
Below is the content of the scripts:
    // var selectedWork = g_form.getValue('regular_work'); //commented out for investigation
    var ajax = new GlideAjax('getCurrentOperationSchedule');
    ajax.addParam('sysparm_name', 'showSchedule');
    // ajax.addParam('sysparm_work', selectedWork); //commented out for investigation
    ajax.getXML(displaySchedule);
    function displaySchedule(response) {
        var currentSchedule = response.responseXML.documentElement.getAttribute("answer");
        g_form.addInfoMessage('The value is'+ currentSchedule); //returned message: The value is null
<Script Include>
var getCurrentOperationSchedule = Class.create();
getCurrentOperationSchedule.prototype = Object.extendsObject(AbstractAjaxProcessor, {
    showSchedule: function() {
        gs.info('Script Include getCurrentOperationSchedule Started');
	// var selectedWork = this.getParameter('sysparm_work'); //commented out for investigation
	return 'test';
    type: 'getCurrentOperationSchedule'
I'm new to ServiceNow and JavaScript, so I expect easy-to-understand comments.
Thanks in advance,
As you're on San Diego, client callable ACLs are created. Are you testing your script include as an admin or by impersonating a user?
Has the necessary ACL been created with a name of getCurrentOperationSchedule?
25 REPLIES 25
@Y.O can you try replacing your on change client script like below
@Mohith Devatte ,
Are your changes only in the following parts?
It's the same value I had set when I posted this question, the result is the same.
Thanks for the confirmation.
No @Y.O i have changed the positions of braces and called the call back function outside the on change function
please try to paste the above code once again and try
Thank you for the explanation. I copied and pasted the script you posted, but unfortunately it returned null as before.
Thank you for your advice.
@Y.O
Did you get a chance to check my below response?
