How to create onChange Client Script against Multi-Row Variable Set?
10-24-2025 12:56 PM
I'm looking for a way to create an onChange catalog client script (employee center request) to watch over the row values.
The Multi-Row variable set has a field called "Amount" that will be added on each input and outside of it there's a field called "Total Amount" that should be updated every time a row is added.
Anyone has been on a similar requirement? Any idea works.
10-25-2025 05:10 AM
so basically outside variable should be updated whenever new row is added?
Also you will have to subtract if user deletes row
this is feasible, follow these links and enhance
Populate field outside MRVS with a total sum of fields inside MRVS
10-26-2025 02:34 AM
Hope you are doing good.
10-27-2025 08:34 PM
