How to create system notification where notification should go to specific users?
Vishal_Jaiswal
Giga Guru
Requirement:
I need to configure a System Notification for the Incident table with the following logic:
  • If Assignment Group = Test Group and Assigned To = Abel Tutor
  • Then the notification should be sent to all members of "Test Group" except the assigned user (Abel Tutor).
What I Tried:
  • Created a notification record in sys_notification.
  • Defined the trigger conditions.
  • Added notification content in the Related List → Content → Next Experience (Subject + Body).
  • Tried defining receiver logic using an email script inside the Next Experience content.
Challenge:
The receiver logic is not working as expected — the notification is not being sent to the intended group members.
Hi @Ankur Bawiskar ,
Thanks again for your response and support.
Observation:
  • Case 1: In my official instance, when I add Assignment Group in the Who will receive tab, no bell notification goes to any user of the group. However, when I try the same in my PDI (Yokohama version), the bell notification goes to all users of the assignment group.
  • Case 2: In my official instance, when I add Assigned To in the Who will receive tab, the bell notification goes correctly to that user.
Conclusion:
It seems this may be either a platform/version issue (Official instance = Xanadu, PDI = Yokohama) or some configuration difference between the two environments.
Solution Implemented:
I changed my approach and found a working solution:
  1. Created a new Event.
  2. Added a Business Rule with logic to exclude the Assigned To user, and stored the sys_ids of all remaining users in the Assignment Group into a comma-separated array.
  3. Triggered the event in the Business Rule.
  4. Linked the event to a sys_notification record.
  5. Created a Next Experience content record for the notification body.
This approach worked successfully in my official instance.
16 REPLIES 16
@Vishal_Jaiswal
did you exclude Assigned to field from recipient list?
when you only include Assignment Group did it send bell notification to Assigned to user as well since that user is group member?
Observation:
Conclusion:
