How to display only unique values from the Reference variable
shaik_irfan
We have a variable Reference Type which is referring to Assignment Group. Our Assignment Group contains duplicate group names ex: Test Group, Test Group, Network, Network
From the Catalog view when the user clicks or search for the Assingment Group we need to display only unique value like if the user types Network, it should display only Network once not multiple
How to acheive this
Last one may not work, This was tougher than I thought, I would really suggest you control the duplicate names at the table level for cost center, This is really not a recommended approach.
I have tested this script and it works, Please try this out
getUniqueCostCenters: function(){
		var ccList = [];
		var uniqueArr = [];
		var ids = [];
		var arrayUtil = new ArrayUtil();
		var cc = new GlideRecord('cmn_cost_center');
		cc.query();
		while(cc.next()){
			ccList.push(cc.name.toString());
		uniqueArr = arrayUtil.unique(ccList);
		ccList = [];
		for(var i=0; i<uniqueArr.length; i++){
			var cc1 = new GlideRecord('cmn_cost_center');
			cc1.addEncodedQuery('nameIN'+uniqueArr[i]);
			cc1.query();
			if(cc1.next()){
				ccList.push(cc1.sys_id.toString());
		return 'sys_idIN'+ccList.toString();
40 REPLIES 40
This community rocks!!! 🙂
