How to enter related incident count of a problem into a field in the problem form?
peterwoodward
Giga Contributor
On the Problem form I have added a field called Related Incident Count.  I need to populate this field with the number incidents that are related to the problem for all open problems.  This way the field can be a column included in a report that can either be printed or appear in a widget on a homepage.
I found a business rule that will display the number of related incidents in the Related Incident Count field.  But because it is a display business rule, it only appears there when the problem is opened.  Because of this, the field does not actually contain any data, so nothing appears in the column of the report.
How do I change this display BR to actually enter the number into the field?
Here is the script:
On the Problem table
// Add your code here
var gr = new GlideRecord("incident");
gr.addQuery('problem_id', "=", current.sys_id);
if (gr.next()) {
//custom string field to store count
current.u_related_incident_count= gr.getRowCount();
})(current, previous);
I have attached a screenshot of the BR.  Any assistance with this is greatly appreciated.
DScroggins
Few things it is not best practice to perform record updating in display business rules. Also when you simply need the count of records using GlideAggregate is best practice and provides better performance as you do not need to return all the records just to get a count. This is what getRecordCount() does. So one thing you could do is add an After Business Rule to the incident table when Problem field changes. The BR would look like:
The advanced script would count all incidents related to the same problem then update the problem record field. If the problem field changes to blank the script will use the previous value:
(function executeRule(current, previous) {
    var incCount = 0;
    var prbSysID = (!current.problem_id.nil())? current.problem_id : previous.problem_id;
    var ga = new GlideAggregate("incident");
    ga.addAggregate('COUNT');
    ga.addQuery('problem_id', prbSysID);
    ga.query();
    if (ga.next()) {
        incCount = ga.getAggregate('COUNT');
    var problemGR = new GlideRecord('problem');
	problemGR.get(prbSysID);
        problemGR.setValue('u_related_incident_count', incCount);
	problemGR.update();
Hope this helps.
--David
peterwoodward
Giga Contributor
Wow.  This works perfectly.  Thank you so very much for your help.
peterwoodward
Giga Contributor
It works perfectly except for one thing I just discovered: if the problem_id field is cleared and the incident is saved, the field is not reflecting this decrement to the number.  How do I account for this?
Odd. When I try the same thing the count is properly updated. If you add the following log statement do you see the count after you add / remove the Problem reference?
    var incCount = 0;
    gs.info('Problem Incident Count Sys ID: ' + prbSysID);
    ga.query();
    if (ga.next()) {
	    gs.info('Problem Incident Count #: ' + incCount);
	    problemGR.update();
