how to extract data from response body.
niveditakumari
How to extract data from response body and set that value in table.
ex - I am calling one API and with that I am getting some records and that are stored in response body. Now I want to extract all the values from response body and set that value in one table.
I am trying to achieve this by schedule job.
Can anyone please help me that how I can extract that values from response body and set that value in our tables.
Nivedita
Hi Nivedita,
the script shared earlier should work; ensure you give correct field names for the 6 fields
try {
var r = new sn_ws.RESTMessageV2('Get Data', 'Default GET');
//override authentication profile
authentication_type ='basic';
r.setAuthenticationProfile(authentication_type, 'efea940d1b408010acf5fc88cc4bcbf7');
var response = r.execute();
var responseBody = response.getBody();
var httpStatus = response.getStatusCode();
gs.print(responseBody);
gs.log("response body is" + responseBody);
var obj = JSON.parse(responseBody);
for(var i = 0; i<obj.plannedEvents.length; i++) {
var gr = new GlideRecord('u_outage');
gr.initialize();
gr.u_rollbackplan = obj.plannedEvents[i].rollbackPlan;
gr.u_plannedeventstartdate = obj.plannedEvents[i].plannedEventStartDate;
gr.u_closurecode = obj.plannedEvents[i].closureCode;
gr.u_description = obj.plannedEvents[i].description;
gr.u_plannedeventenddate = obj.plannedEvents[i].plannedEventEndDate;
gr.u_ticketid = obj.plannedEvents[i].ticketId;
gr.u_correlationid = obj.plannedEvents[i].correlationId;
gr.u_impact = obj.plannedEvents[i].impact;
gr.u_executionowner = obj.plannedEvents[i].executionOwner;
gr.u_maintenancetype = obj.plannedEvents[i].maintenanceType;
gr.u_sitelocation= obj.plannedEvents[i].maintenanceType;
gr.u_expecteddowntime= obj.plannedEvents[i].expectedDowntime;
gr.u_activitystatus= obj.plannedEvents[i].activityStatus;
var servicesArray = [];
for(var j = 0; j<obj.plannedEvents[i].services.length; j++) {
var gr = new GlideRecord('services_table');
gr.initialize();
gr.u_serviceidentifier= obj.plannedEvents[i].services[j].serviceIdentifier;
gr.u_protectionstatus= obj.plannedEvents[i].services[j].protectionStatus;
gr.u_servicetype= obj.plannedEvents[i].services[j].serviceType;
gr.u_servicealias= obj.plannedEvents[i].services[j].serviceAlias;
gr.u_customerlename= obj.plannedEvents[i].services[j].customerLeName;
gr.u_cuid= obj.plannedEvents[i].services[j].cuid;
var sysId = gr.insert();
servicesArray.push(sysId.toString());
gr.u_services = servicesArray.toString();
gr.insert();
gs.log("table data is" + responseBody);
catch(ex) {
gs.info('Exception is: ' + ex);
55 REPLIES 55
Can you please help me with this.
Nivedita
Hello Ankur,
Can you please help me with this to getting data one by one and set into custom table.
Nivedita
Hello Ankur,
I have tried below code but i am getting undefined value :
Nivedita
Hi Nivedita,
what information from the json you want to extract?
Are you referring to the services which is an array of json objects? the array length is 4
If yes then sample code below
var str = '{"status":"200","message":"Success","totalCount":1,"startIndex":0,"endIndex":0,"plannedEvents":[{"closureCode":null,"rollbackPlan":"Test","plannedEventStartDate":"2018-05-24 07:06:30","siteLocation":"Test","ticketId":"CHGP0054939","description":"Test Ticket . Please dont close it.","maintenanceType":"Normal","impact":"Test","correlationId":null,"executionOwner":"Tata Backbone Network","plannedEventEndDate":"2018-05-25 07:06:56","services":[{"serviceIdentifier":"TEST1-CN-862128916674-G-MPLS_duplicate","protectionStatus":"Protected","serviceType":"GVPN - MPLS","serviceAlias":"","customerLeName":"TATA Communications Test1","cuid":"1"},{"serviceIdentifier":"TEST1-GB-441926640000-IP-DIA-40","protectionStatus":"Protecting","serviceType":"IP - DIA","serviceAlias":"","customerLeName":"TATA Communications Test1","cuid":"1"},{"serviceIdentifier":"TEST1-GB-040237-I-TPAAS-02","protectionStatus":"Unprotected","serviceType":"Infrastructure - TPaaS","serviceAlias":"","customerLeName":"TATA Communications Test1","cuid":"1"},{"serviceIdentifier":"TEST1-GB-040237-G-MPLS-01","protectionStatus":"Protection failure","serviceType":"GVPN - MPLS","serviceAlias":"","customerLeName":"TATA Communications Test1","cuid":"1"}],"expectedDowntime":"00:02:45","activityStatus":"Scheduled"}]}';
var parser = new JSONParser();
var parsedData = parser.parse(str);
for(var i=0;i<parsedData.plannedEvents[0].services.length;i++){
gs.info(parsedData.plannedEvents[0].services[i].serviceIdentifier);
gs.info(parsedData.plannedEvents[0].services[i].protectionStatus);
gs.info(parsedData.plannedEvents[0].services[i].serviceType);
gs.info(parsedData.plannedEvents[0].services[i].serviceAlias);
gs.info(parsedData.plannedEvents[0].services[i].customerLeName);
gs.info(parsedData.plannedEvents[0].services[i].cuid);
screenshot below
Hello Ankur,
I need to extract all the values from JSON and then import that values in my custom table.
I have created one custom table for all these fields.
Nivedita
