how to extract data from response body.
niveditakumari
How to extract data from response body and set that value in table.
ex - I am calling one API and with that I am getting some records and that are stored in response body. Now I want to extract all the values from response body and set that value in one table.
I am trying to achieve this by schedule job.
Can anyone please help me that how I can extract that values from response body and set that value in our tables.
Nivedita
Hi Nivedita,
the script shared earlier should work; ensure you give correct field names for the 6 fields
try {
var r = new sn_ws.RESTMessageV2('Get Data', 'Default GET');
//override authentication profile
authentication_type ='basic';
r.setAuthenticationProfile(authentication_type, 'efea940d1b408010acf5fc88cc4bcbf7');
var response = r.execute();
var responseBody = response.getBody();
var httpStatus = response.getStatusCode();
gs.print(responseBody);
gs.log("response body is" + responseBody);
var obj = JSON.parse(responseBody);
for(var i = 0; i<obj.plannedEvents.length; i++) {
var gr = new GlideRecord('u_outage');
gr.initialize();
gr.u_rollbackplan = obj.plannedEvents[i].rollbackPlan;
gr.u_plannedeventstartdate = obj.plannedEvents[i].plannedEventStartDate;
gr.u_closurecode = obj.plannedEvents[i].closureCode;
gr.u_description = obj.plannedEvents[i].description;
gr.u_plannedeventenddate = obj.plannedEvents[i].plannedEventEndDate;
gr.u_ticketid = obj.plannedEvents[i].ticketId;
gr.u_correlationid = obj.plannedEvents[i].correlationId;
gr.u_impact = obj.plannedEvents[i].impact;
gr.u_executionowner = obj.plannedEvents[i].executionOwner;
gr.u_maintenancetype = obj.plannedEvents[i].maintenanceType;
gr.u_sitelocation= obj.plannedEvents[i].maintenanceType;
gr.u_expecteddowntime= obj.plannedEvents[i].expectedDowntime;
gr.u_activitystatus= obj.plannedEvents[i].activityStatus;
var servicesArray = [];
for(var j = 0; j<obj.plannedEvents[i].services.length; j++) {
var gr = new GlideRecord('services_table');
gr.initialize();
gr.u_serviceidentifier= obj.plannedEvents[i].services[j].serviceIdentifier;
gr.u_protectionstatus= obj.plannedEvents[i].services[j].protectionStatus;
gr.u_servicetype= obj.plannedEvents[i].services[j].serviceType;
gr.u_servicealias= obj.plannedEvents[i].services[j].serviceAlias;
gr.u_customerlename= obj.plannedEvents[i].services[j].customerLeName;
gr.u_cuid= obj.plannedEvents[i].services[j].cuid;
var sysId = gr.insert();
servicesArray.push(sysId.toString());
gr.u_services = servicesArray.toString();
gr.insert();
gs.log("table data is" + responseBody);
catch(ex) {
gs.info('Exception is: ' + ex);
55 REPLIES 55
Hello Ankur,
I was also doing the same but when I am running this code it is showing me error like "not authorized"
Below is my code :
try {
r.setAuthenticationProfile(authentication_type,'efea940d1b408010acf5fc88cc4bcbf7');
for(var i = 0; i<obj.plannedEvents.length;i++) {
gs.print("##planned values##"+obj.plannedEvents[i].closureCode);
gs.print("##planned values##"+obj.plannedEvents[i].rollbackPlan);
gs.print("##planned values##"+obj.plannedEvents[i].plannedEventStartDate);
gs.print("##planned values##"+obj.plannedEvents[i].siteLocation);
gs.print("##planned values##"+obj.plannedEvents[i].ticketId);
gs.print("##planned values##"+obj.plannedEvents[i].description);
gs.print("##planned values##"+obj.plannedEvents[i].maintenanceType);
gs.print("##planned values##"+obj.plannedEvents[i].impact);
gs.print("##planned values##"+obj.plannedEvents[i].correlationId);
gs.print("##planned values##"+obj.plannedEvents[i].executionOwner);
gs.print("##planned values##"+obj.plannedEvents[i].plannedEventEndDate);
for(var j = 0;j<obj.plannedEvents[i].services.length;j++) {
gs.print("##Service values###"+obj.plannedEvents[i].services[j].serviceIdentifier);
gs.print("##Service values###"+obj.plannedEvents[i].services[j].protectionStatus);
gs.print("##Service values###"+obj.plannedEvents[i].services[j].serviceType);
gs.print("##Service values###"+obj.plannedEvents[i].services[j].serviceAlias);
gs.print("##Service values###"+obj.plannedEvents[i].services[j].customerLeName);
gs.print("##Service values###"+obj.plannedEvents[i].services[j].cuid);
gs.print("##planned Description##"+obj.plannedEvents.length);
gs.print("##Service###"+obj.plannedEvents[0].services.length);
gs.print("##Hello##"+obj.message);
//var parser = new global.JSON();
//var parsed = parser.decode(responseBody);
//gs.log("Parsed Data1:"+parsed.result.siteLocation);
gs.log('responsebody is' + responseBody);
catch(ex) {
var message = ex.message;
Can you please suggest me where i am doing wrong.
Nivedita
Hello Ankur,
Thank you so much for your help.
I tried to get all the values but it is showing as "not authorized" don't know why.
Can you please help me on how i can get all the values from JSON and import that values in my custom table.
Nivedita
Hello Ankur,
Now my code is working as expected. I am getting all the values from JSON.
I need to import these values to my table.
Could you please help me with this.
Nivedita
Hi Nivedita,
once you get the values now you need to know to which table you need to insert and what values you want to insert i.e. map value to particular field of table
Hello Ankur,
Thank you so much for your reply.
I need to insert all the data into my custom table.
I have written below code but when i am running this background script it is showing some output. When i see my custom table then data is not filled in table.
Below is my code :
try {
gr.initialize();
gr.insert();
catch(ex) {
Below is my output :
Could you please tell me where I am doing wrong.
Nivedita
