how to extract data from response body.
niveditakumari
How to extract data from response body and set that value in table.
ex - I am calling one API and with that I am getting some records and that are stored in response body. Now I want to extract all the values from response body and set that value in one table.
I am trying to achieve this by schedule job.
Can anyone please help me that how I can extract that values from response body and set that value in our tables.
Nivedita
Hi Nivedita,
the script shared earlier should work; ensure you give correct field names for the 6 fields
try {
var r = new sn_ws.RESTMessageV2('Get Data', 'Default GET');
//override authentication profile
authentication_type ='basic';
r.setAuthenticationProfile(authentication_type, 'efea940d1b408010acf5fc88cc4bcbf7');
var response = r.execute();
var responseBody = response.getBody();
var httpStatus = response.getStatusCode();
gs.print(responseBody);
gs.log("response body is" + responseBody);
var obj = JSON.parse(responseBody);
for(var i = 0; i<obj.plannedEvents.length; i++) {
var gr = new GlideRecord('u_outage');
gr.initialize();
gr.u_rollbackplan = obj.plannedEvents[i].rollbackPlan;
gr.u_plannedeventstartdate = obj.plannedEvents[i].plannedEventStartDate;
gr.u_closurecode = obj.plannedEvents[i].closureCode;
gr.u_description = obj.plannedEvents[i].description;
gr.u_plannedeventenddate = obj.plannedEvents[i].plannedEventEndDate;
gr.u_ticketid = obj.plannedEvents[i].ticketId;
gr.u_correlationid = obj.plannedEvents[i].correlationId;
gr.u_impact = obj.plannedEvents[i].impact;
gr.u_executionowner = obj.plannedEvents[i].executionOwner;
gr.u_maintenancetype = obj.plannedEvents[i].maintenanceType;
gr.u_sitelocation= obj.plannedEvents[i].maintenanceType;
gr.u_expecteddowntime= obj.plannedEvents[i].expectedDowntime;
gr.u_activitystatus= obj.plannedEvents[i].activityStatus;
var servicesArray = [];
for(var j = 0; j<obj.plannedEvents[i].services.length; j++) {
var gr = new GlideRecord('services_table');
gr.initialize();
gr.u_serviceidentifier= obj.plannedEvents[i].services[j].serviceIdentifier;
gr.u_protectionstatus= obj.plannedEvents[i].services[j].protectionStatus;
gr.u_servicetype= obj.plannedEvents[i].services[j].serviceType;
gr.u_servicealias= obj.plannedEvents[i].services[j].serviceAlias;
gr.u_customerlename= obj.plannedEvents[i].services[j].customerLeName;
gr.u_cuid= obj.plannedEvents[i].services[j].cuid;
var sysId = gr.insert();
servicesArray.push(sysId.toString());
gr.u_services = servicesArray.toString();
gr.insert();
gs.log("table data is" + responseBody);
catch(ex) {
gs.info('Exception is: ' + ex);
55 REPLIES 55
Hello Ankur,
If i remove those tabs from outage table then how i will store 4 different values for services?
Could you please suggest me.
Nivedita
Hi Nivedita,
So after removing the 4 tabs from the form layout you can show the 4 services as below
1) you already have a List Type of field on Outage form which stores Services information
2) consider 4 services records are created from json; then you are pushing sys_ids of those into an array
3) you are setting the list type of field with these 4 record sys_ids
So indirectly 1 outage record will have information of 4 Services record
It is similar to incident watch_list field where you can store multiple users
Hello Ankur,
Thank you so much for your reply.
I got your point but how I can show outage information with services information in outage form.
Could you please suggest me the steps So that I can show all information in outage form.
What could be steps for that.
Nivedita
Hi Nivedita,
So your code to create 4 services record is working fine; Also the list type of field is getting populated with the 4 services record.
you can show them on form using related list or creating a relationship between those 2 tables
Hello Ankur,
My code to create 4 services record is not  working Also the list type of field is not getting populated with the 4 services record.
Can you please help me with this.
I have created services table separate but record is not created in services table.
Nivedita
