How to get a banner frame and gear icon (system settings) on my Instance?
Charise Scott
Kilo Explorer
Hello All,
When I created my Developer account it gave me the "App Engine Creator" User Role and I created my instance. I've since changed my User Role to "Admin". While my Instance shows up as Admin, I don't have a banner at the top or the gear icon for System Settings. How do I get them?
Attached is a screenshot and thanks in advance.
12 REPLIES 12
No... unfortunately there's no show update set picker in header or show application picker in header in San Diego.
You only have this:
Kind regards,
Mark
2020-2022 ServiceNow Community MVP
2020-2022 ServiceNow Developer MVP
LinkedIn
Community article, blog, video list
I don't have a globe, only a question mark inside a circle.
BiancaKerchhoff
HI Mark
I am also having this problem. I am looking for the gear icon because I would like to go to the delegated developer option in System Settings. Can you please help?
Ben Justice
Kilo Explorer
I have the same issue.  The system settings gear icon is missing.  I'm doing a lab and the first step is to click on the system settings gear icon to get to the developer tab.
Hi
Can you please try to use this shortcut ctrl+alt+a and see it shows or not
