How to get display value of select box variable in flow designer?
apjohn2
Hi everyone. Will try to keep this succinct.
Context: Service Catalog Flow > Create Catalog Task > Short Description > script >
I need to get the display value of a select box variable choice to help populate short description. I cannot get this value. I have tried "getDisplayValue" and "getLabel" functions and both return "undefined".
NOTE: I have looked in community but only find answers for what is apparently old functionality in Flow scripts, e.g., "fd_data.trigger.current.variables..." etc., but that no longer works because "variables" is not an option any longer from the trigger record. We therefore are using "fd_data._1__get_catalog_variables..." instead.
This is the non-functional script:
var sfuser = fd_data._1__get_catalog_variables.shop_floor_user;
var removeAllOrSome = fd_data._1__get_catalog_variables.remove_all_or_some.getDisplayValue();
gs.info(removeAllOrSome);
var sdesc = sfuser ? "Remove access - Mobile Device Login Only" : "Remove ERP access - " + removeAllOrSome;
return sdesc;
Please advise if you know how to do this; thank you!
apjohn2
Somehow my search skills kicked in and I was able to find this:
KB0960074
That basically says you can't get display values for select box choices in Flow designer and you have to look them up in the script, so that's what I did. Here is the updated script, which works fine:
var removeAllOrSome = fd_data._1__get_catalog_variables.remove_all_or_some;
Next, we have to use glide record query to Look up the display value for the selected 'remove_all_or_some' choice
Ref: https://support.servicenow.com/kb?id=kb_article_view&sysparm_article=KB0960074
var qc = new GlideRecord('question_choice');
qc.addQuery('question','a7509b79db10589005c96ce2ca961997');
qc.addQuery('value',removeAllOrSome);
qc.query();
if (qc.next()) {removeAllOrSome = qc.text;}
return sdesc;
Hi @gjz , @purdue ,
Sorry I missed the earlier response. Attached an XML of a global action to retrieve the variable displayValue.
Hayo
M-Gren
I have tried playingaround with this since I would like to return the Variable.Text and not the Variable.Value in a record producer.
As far as I can see the question Sys_id is uniq for each choice in the select box variable, which makes this very cumbersome if I have a select box with (for instance) 10 choices, which if I understand this correctly leaves me with hardcoding 10 seperate combinations of Value and Question SysIDS..
Any input or ideas on how to obtain, what I am looking for , would be much apreciated 🙂
Al I want is to be able to return the Label (of the selected choice) from a select box type variable (on a incident record producer), because I want to include the selected (Value's Label) in the description field on the incident.
What inputs and outputs did you use?
Chad
rudipohjaniemi
In case someone is still struggling with this in 2026:
.getDisplayValue() actually works if you do it on the TRIGGER instead of doing it on a "Get Catalog Variables" activity.
This works:
var managed_by = fd_data.trigger.request_item.variables.managed_by.getDisplayValue();
