‎03-21-2025 03:36 AM
I need to get the user or group members emails and sys Ids and sysIds format should be such a way that I can assign them directly to additonal assignee list while I am creating catalog task through oob create catalog task.
But I am not sure what went wrong I am not able to run the script and its producing the error as shown in below??
Can anyone modify the code or correct me what is the wrong?
@Ankur Bawiskar
email format should be same way so that third party system can understand / differentiate mails by ";".
gs.log("array of sys ids entry:"+inputs.approvallist);
var emails = '';
if(inputs.group){
var groupmembers = new GlideRecord("sys_user_grmember");
groupmembers.addQuery("group",inputs.group);
groupmembers.addExtraField("user.email");
groupmembers.query();
while (groupmembers.next) {
emails += groupmembers.user.email + ';';
outputs.emaillist = emails.slice(0, -1);
}else if(inputs.assignedto){
var userGr = new GlideRecord("sys_user");
userGr.get(inputs.assignedto);
outputs.emaillist = userGr.email;
else if(inputs.approvallist){
for(var i=0; i<inputs.approvallist.length; i++){
var userGr1 = new GlideRecord("sys_user");
userGr1.get(inputs.approvallist[i]);
emails += userGr1.email + ';';
})(inputs, outputs);Solved! Go to Solution.
‎03-21-2025 03:43 AM
@Community Alums
not sure why you are using slice, but here is the updated code
try this and let me know
gs.log("array of sys ids entry:" + inputs.approvallist);
var emails = [];
if (inputs.group) {
groupmembers.addQuery("group", inputs.group.sys_id);
while (groupmembers.next()) {
emails.push(groupmembers.user.email.toString());
outputs.emaillist = emails.toString();
} else if (inputs.assignedto) {
outputs.emaillist = userGr.email.toString();
} else if (inputs.approvallist) {
for (var i = 0; i < inputs.approvallist.length; i++) {
emails += userGr1.email + ',';
‎03-21-2025 05:37 AM
@Community Alums
Please try with the below. I believe it would work if you have given the field datatypes correctly.
var emails = [];
var groupID = inputs.group;
var assignedTo = inputs.assignedto;
var approvalList = inputs.approvallist
if (groupID) {
groupmembers.addEncodedQuery("group=", groupID);
emails.push(groupmembers.user.email);
} else if (assignedTo) {
userGr.get(assignedTo);
emails.push(userGr.email);
} else if (approvalList) {
for (var i = 0; i < approvalList.length; i++) {
userGr1.get(approvalList[i]);
emails.push(userGr1.email);
outputs.emaillist = emails.join(';');
Please mark my response as helpful and accept it as solution if it solved your problem.
Thanks & Regards,
Aniket Dey
‎03-23-2025 09:36 PM
@Community Alums
yes that will be an extra step
@Community Alums
var emails = [];
if (groupID) {
Thanks & Regards,
Aniket Dey
