how to get multi row variable set variables in flow designer
Madala Chaitany
Giga Guru
In flow designer I need to get exact variable for multi row variable set. e.g. I have choice type and list collector type,
Based on those outputs, I'm having some conditions in flow designer. I had tried but i'm got getting it.
Please help me out.
Thanks & Regards,
Chaitanya
shloke04
Hi @Madala Chaitanya Kumar
Starting from Paris Multi Row Variable set variables are accessible in Flow Designer. How you will be doing this is clearly mentioned in thread below:
https://community.servicenow.com/community?id=community_question&sys_id=9957d7cadb3fdc903daa1ea668961966
If you prior to Paris version then you need to have a look at below threads:
https://community.servicenow.com/community?id=community_question&sys_id=e4f5ffb0db40e8d0190b1ea668961933
https://community.servicenow.com/community?id=community_question&sys_id=0500bc19dbc8338ca39a0b55ca961908&view_source=searchResult
Shloke
Shloke
