How to get record producer variable (answered questions label and answer) into description
attanhes
I have a record producer with 20 multiple-choice variable questions. I only need answered questions by concatenating answered with questions label and answered into the descriptions field only for those multiple-choice questions.
I tried the below script in record producer script to get only answered questions label and values but unfortunately, it is not working.
var gr = new GlideRecord('question_answer');
    //gr.addQuery('table_sys_id', current.sys_id); //sys_id of record in question  5312acc4dbab34102721455215961993
 gr.addQuery('table_sys_id', '85e5f5dcdbabf050691a7b53f39619af'); //sys_id of record in question  5312acc4dbab34102721455215961993 incident
gs.log("Current SysID " + current.getUniqueValue());
    var comments = '';
    while (gr.next()) {
      if (gr.value && gr.question.type == 3) { //exclude questions with empty values
		//if (gr.value) { //exclude questions with empty values
      comments += gr.question.getDisplayValue() + ":   " + gr.value.getDisplayValue() + "\n"; //display question and answer
    current.comments = comments;
current.description = comments;
Can someone please help me to work this out?
attanhes
I just worked this out by creating a new before insert business rule in the incident table by adding above script.
Hi Alan,
In which table I should write this before insert business rule? This record producer creates incident records.
attanhes
attanhes
I have further developed this script by adding more functions. Just adding my script into this thread in case it might be helpful for others.
    //gr.addQuery('table_sys_id', '85e5f5dcdbabf050691a7b53f39619af'); //sys_id of record in question  5312acc4dbab34102721455215961993 incident
    //gs.log("Current SysID " + current.getUniqueValue());
    var choice = '';
    var descript = '';
	var category = '';
    while (gr.next()) {
        //if (gr.value){//exclude questions with empty values
       if (gr.value && gr.question.type == 3 && gr.question.name != "v_facilities_incident_category" )
		//if (gr.value && gr.question.type != 6 && gr.question.type != 8 ) {
            choice += gr.question.getDisplayValue() + " : " + "\n" + gr.value.getDisplayValue() + "\n"; //display question and answer
			else if (gr.question.type == 2)
				descript += gr.value.getDisplayValue() + "\n";
			else if (gr.question.name == "v_facilities_incident_category")
				category += gr.question.getDisplayValue() + " : "+ gr.value.getDisplayValue() + "\n";
    current.description = "============== Category Type ============== " + "\n"+ category
		+ "\n" + "============== Choices ==============" + "\n" + choice
		+ "\n" + " ============== Description ==============" + "\n" + descript;
    //current.comments = descript;
	current.work_notes = "============== Category Type ============== " + "\n"+ category
})(current, previous);
This script helps to print the details into description as in below format
