02-12-2025 11:16 AM
I have a table where I have 2 columns named Directory and Roles. Now Directory can be same on multiple records, I need help to print out the value of all Roles for the same directory in 1 single line.
For example, this is how my table is structured:
There are 2 D1 which are having 2 different Roles R1 and R3. Similarly for D2, there are 2 roles R2 and R4
Output:
R1,R3
R2,R4I have tried below script so far to group by using glide aggregate but this is not working. Both Directory and Roles are reference attributes
var gr = new GlideAggregate('tableName');
gr.addEncodedQuery('my query');
gr.groupBy('directory');
//gr.setGroup(false);
while(gr.next()){
gs.info(gr.getValue('roles'));
}Kindly assist on how can i achieve the above output.
Surbhi
02-12-2025 11:54 PM
try this
var gaUser = new GlideAggregate('tableName');
gaUser.addAggregate('count');
gaUser.orderByAggregate('count');
gaUser.groupBy('directoryField');
gaUser.addEncodedQuery('my query');
gaUser.query();
while(gaUser.next()){
var roleCount = gaUser.getAggregate('count');
gs.info('Directory: ' + gaUser.directoryField + ' has roles : ' + roleCount);
I used something similar on sys_user and it worked for me
02-12-2025 11:54 PM
try this
gaUser.query();
02-13-2025 07:59 PM
02-13-2025 08:00 PM
Hello @Ankur Bawiskar ,
Thanks for the above response. I tired and your script helps me display the count of roles which I have for each directory.
I was looking for to display the names of those roles comma separated against each directory. Currently as per you script where you helped me it's just showing me the count of those.
Can you please help me on this.
02-13-2025 08:22 PM
Any thoughts on above if it can be achieved. Is there an alternative solution you can assist to achieve the same?
02-13-2025 08:40 PM
for that you can enhance the script further.
