How to hide a mandatory field using catalog client script?
10-30-2025 10:07 PM
I've written a onChange catalog client script on Subcategory field. whenever a specific subcategory is selected then the description field should be visible and should become mandatory. After Subcategory value changes back to --None-- the description field should be hidden (vice versa). I have written below script. It is not working.
And we are adding category and subcategory choices via catalog client script. As these variables are from Variable set. How can I achieve this same functionality via catalog UI Policy.
if (newValue == 'create_a_new_local_gcajob/sub_family') {
g_form.setDisplay('description', true);
g_form.setMandatory('description', true);
else
10-30-2025 11:13 PM
Hi @The Matrix ,
I tried your problem in my PDI and it is working fine for me
Can you please try with UI Policy,
Create UI Policy Action
Result
When Option one is selected description is mandatory
When Option two is selected description is not visible
Please mark my answer correct and helpful if this works for you
Thanks and Regards,
Sarthak
10-30-2025 11:47 PM
try this once -> do clear the description when you are hiding it
if (isLoading)
if (newValue == 'create_a_new_local_gcajob/sub_family') { // use correct value to compare
g_form.setMandatory('description', false);
g_form.clearValue('description');
g_form.setDisplay('description', false);
01-07-2026 10:27 PM
Hope you are doing good.
10-31-2025 12:12 AM
Hi @The Matrix
if (isLoading) return;
// Target variable name: 'description'
11-01-2025 02:35 AM
@The Matrix if you feel like I am able to solve the problem .. Please accept the solution on the same !!
