How to hide a process flow formatter until it reaches a particular state?
‎03-22-2021 03:15 AM
So basically I have to hide the process flow formatter showing various states for a table until it reaches to a particular state.
For example consider this image:
Let assume the formatter will be hidden till it reaches Fix in Progress.
Is there anyway that this can be acheived?
Script Debugger
Scripting and Coding
‎03-22-2021 05:35 AM
‎04-12-2021 02:31 AM
Hope you are doing good.
If so, please mark appropriate response as correct & helpful so that the question will appear as resolved for others who may have a similar question in the future.
Thanks!
‎04-14-2021 11:32 PM
Thanks!
‎08-23-2021 11:04 AM
Hello Ankur,
I had a similar requirement for which your solution helped. However, there was one limitation for me
My requirement was to hide the flow formatter if it is a new record, for which I created a view, and hide the flow formatter by using DOM manipulation based on the view.
When I did that, the reference fields on the form were not loading the lookup list. No action when I clicked on the magnifying glass icon on the reference field.
Is there any other way to hide the flow formatter other than using DOM Manipulation
Thank you in advance
Parthiban
‎11-16-2022 12:22 PM - edited ‎11-16-2022 12:24 PM
This worked for me to remove the Review item from the formatter when not in Review, from the change_request table, t:
onLoad Client Script:
if(g_form.getValue('state') != 0){
$j("a:contains('Review')").parent("li").hide();
TL;DR
This looks in the document for anchor tags, <a>, and further looks to see if it contains the keywords I want, in this case 'Review'. Then it finds the parent <li> tag and hides it, along with the anchor within it.
