How to hide annotation using client script for scoped application
Karishma Dubey
Hi Team,
I was trying to hide annotation for specific related service. However, it is not working. Please suggest. Related services is a reference field. Isolate script is false and UI type = "All"
//onload client scipt
  var rel_services = g_form.getReference('related_service').toString();
    //getValue('related_service');
    alert(rel_services);
     if (rel_services == "67a3e8301b8c62d00b9a11739b4bcba2") {
         info1.style.display = 'block';
     else{
        info1.style.display = 'none';
17 REPLIES 17
@Karishma Dubey
the client script which is populating that related_services field, there only you add the logic to show/hide annotation
@Ankur Bawiskar
I added and now it is going inside if but it is not hiding the annotation
function onLoad() {
    //var anno = document.getElementsByClassName("annotation");
    var rel_services = g_form.getValue('related_service').toString();
        alert('inside if');
         document.getElementById('info1').style.display = 'block';
        document.getElementById('info1').style.display = 'none';
        //$('info1').up().hide();
        alert('inside else');
        document.getElementById('info1').style.display = ''; // show
@Karishma Dubey
to hide it should be set as none
Ensure Isolate Script = False for your onLoad client script
try this
function onLoad() {
        alert('inside if');
@Ankur Bawiskar I tried with both none and block. it is going inside if but not hiding the annotation
@Karishma Dubey
Isolate Script = False?
Also can you check by using javascript debugger pressing Ctrl+Shift+Alt+J on form.
Then add your code there and see if it's working by Running the code
