How to hide annotation using client script for scoped application
Karishma Dubey
Hi Team,
I was trying to hide annotation for specific related service. However, it is not working. Please suggest. Related services is a reference field. Isolate script is false and UI type = "All"
//onload client scipt
  var rel_services = g_form.getReference('related_service').toString();
    //getValue('related_service');
    alert(rel_services);
     if (rel_services == "67a3e8301b8c62d00b9a11739b4bcba2") {
         info1.style.display = 'block';
     else{
        info1.style.display = 'none';
17 REPLIES 17
TheHuyC
Hope this helps
// onload client script
window.onload = function () {
    // Get the related service reference
    // Get the element with ID 'info1'
    var info1 = document.getElementById('info1'); // Replace 'info1' with the actual ID
    // Ensure the element exists before manipulating it
    if (info1) {
        if (rel_services === "67a3e8301b8c62d00b9a11739b4bcba2") {
        console.error("Element with ID 'info1' not found.");
Chaitanya ILCR
Giga Patron
Hi @Karishma Dubey ,
Try this with isolate script as false
function onLoad() {
    $('info1').up().hide();
    var rel_services = g_form.getValue('related_service');
        $('info1').up().show();
is related_service field available on the form?
if no
create a display BR with
g_scratchpad.relatedService = current.getValue('related_service')
client script with isolate script false
function onLoad() {
    if (g_scratchpad.relatedService == "67a3e8301b8c62d00b9a11739b4bcba2")
Chaitanya
_ukasz Rybicki
Giga Guru
Analysis of answer
  • DOM ID assumption: I assumed the <span id="info1"> ID won’t change; in reality it can vary per form or UI theme—inspect and confirm the ID first.
  • Field value timing: I used g_form.getValue() synchronously, which works on form load, but if the field is populated via UI Policy or asynchronous script, you may need an onChange script or a short setTimeout.
  • Alternative omission: I focused on client scripting and didn’t propose a UI Policy or UI Action approach, which can be no-code/OOTB for showing/hiding annotation fields.
  • Isolate script: I didn’t explicitly remind to set Isolate Script = false so the script can access the DOM element.
Final Solution
Name of Problem
Hide InfoBox Blue annotation by related_service value
General proposal (≤100 words)
On an onLoad Client Script, read the sys_id from related_service via g_form.getValue(), locate the annotation <span> by document.getElementById(), and toggle its style.display. Ensure Isolate Script is disabled. 😊 (ServiceNow)
Detailed proposal (≤250 words)
  1. Identify the annotation element
    • Inspect form HTML → confirm your <span id="info1">…</span> ID.
  2. Create Client Script
    • Type: onLoad
    • Isolate Script: false
    • UI Type: All
  3. Script code
    // onLoad Client Script
    function onLoad() {
      // 1. Get related_service sys_id
      var relId = g_form.getValue('related_service');
      // 2. Locate annotation span
      var infoEl = document.getElementById('info1');
      if (!infoEl) return; // nothing to do
      // 3. Toggle visibility
      if (relId === '67a3e8301b8c62d00b9a11739b4bcba2') {
        infoEl.style.display = '';    // show
        infoEl.style.display = 'none';// hide
  4. Alternative
    • Use a UI Policy on related_service with a Run Script action calling the same DOM logic.
  5. Manual steps
    • Ensure the annotation is on the form via Form Designer > Annotations.
    • Confirm field name related_service.
    • Add the Client Script record and deploy.
Example solution (≤100 words)
A scoped onLoad Client Script on a Change Request form retrieves the selected related_service ID and hides a blue info box advising cost-entry rules unless the service matches a specific catalog item. This prevents clutter for non-applicable services. 😊
Sources
  1. How to hide annotation using client script for scoped application (ServiceNow Community) – recommends g_form.getValue() and document.getElementById() for show/hide logic (ServiceNow).
  2. Administering form annotations (ServiceNow Docs) – explains annotation HTML structure and the need to disable isolate script for DOM access (ServiceNow).
Please mark this as the correct answer!
