How to insert approvals using a script
sk59
I would like to insert an approval using a BR. Please let me know how to achieve this.
I have a field ABC(glide_list), I want to add the approvers in this field as approvers when a change is completed.
Thanks in Advance
Sorry below one is the corrected script:
// Add your code here
var app = current.u_groups;//Where groups are selected
gs.addInfoMessage(app);
var spl = app.split(',');
var len = spl.length;
for(var i=0;i<len;i++)
gs.addInfoMessage(i);
var m = new GlideRecord('sysapproval_group');
m.initialize();
m.parent= current.sys_id;
m.assignment_group = spl[i];
m.approval = 'requested';
m.insert();
})(current, previous);
Ashutosh
Don't forget to mark it as correct
23 REPLIES 23
Hi Ashutosh,
Record got created but it looked something like this.
HI,
What i will suggest is to try below code with hardcoded value of approver.
Use below code:
var m = new GlideRecord('sysapproval_approver');
m.initialize();
m.sysapproval= current.sys_id;
m.approver = 'Give sys id of user in this single quotes';
m.state = 'requested';
m.insert();
Let me know if the approver name come's in or not.
Ashutosh Munot
Approver name has come now.
Hi, Since you have mentioned a glide list field here. so just modify the above script and this would work.
var usr= current.field_name.split(',');
for (var i = 0; i < usr.length; i++)
m.initialize();
m.approver = usr[i];
m.insert();
if this can be done through workflow approval then, use:
var answer;
for (var i = 0; i < usr.length; i++){
answer.push(usr[i]);
else simply in the workflow approval , set the field to use as ABC.
Hi Ashutosh,
I need to do this by script instead of workflow.
The same script is used earlier where the approver and assignement group values are coming as blank
