How to make a variable visible/invisible based on another variable.
ramandeep
Dear Friends,
I have a Catalog Item. There i have one check box type variable(Let us say abc) and two date type variables(let us say mno and pqr). I want if abc variable is checked then mno and pqr variables should be visible otherwise these(mno and pqr) should remain invisible. Can you please tell how can I achieve that?
Thank you
Ramandeep
Pradeep Sharma
Hi Ramandeep,
With screenshots
13 REPLIES 13
You Can use Catalog UI policy for this req.
Hi Pradeep,
Thank you for the update! As I mentioned I have created above catalog client script. It is working fine but I just want that when I open the Item mno and pqr variables should be invisible. I created "onChange" client script and it should run when I open Item but this is not happening.
Thank you
Ramandeep
Pradeep Sharma
Hi Ramandeep,
With screenshots
ok. I am creating this UI Policy now but I am afraid if it will hide mno and pqr when I open the item.
u have only created the client script right?
make ui policy like I said. it will work fine. those two fields will b inivisible when form loads.this what u want I guess.
