01-23-2025 08:33 PM
I am trying to map the choice field of a snow user profile through flow designer. we get user data through an integration and value should be mapped to field in snow user profile dynamically based on the input we receive as we have different choice values in snow end. trying with below script but it is returning empty value:
01-23-2025 08:50 PM
Hi @klavan32
Please check the following points:
1. Remove if (get(empType)) from your script.
2. What is the value being returned by employee_type variable. For that, please check the flow execution context and see the value. Compare the value being returned with your if-else logic.
3. If the empType variable is being set properly, check for the choice field values. As per your script, your choice field has values like full_time_employee etc. Please cross-verify the same.
Thanks and Regards
Amit Verma
01-27-2025 06:04 AM
seems you have not configured the output variable correctly
the script step should also have an output variable and that needs to be mapped to the Outputs variable section
01-27-2025 06:42 PM
Hi @Ankur Bawiskar in script step also, we have declared the variable and mapped the input but somehow the variable names are not matching with the one in script step and the one we created in outputs section, If i am trying to create new variable in script section, its not showing up in data pill ,even though i save and publish multiple times, so i am unable to map new one to output variable
I have tried to map the input to already existing script variables just for testing, its working fine and returning the value in log
01-27-2025 07:14 PM
ensure variable name is consistent. I have seen sometimes issue when we capitalize the variable
give something like this employeetype
