how to match the Worknotes values dynamically using Business rule
Ajay Singh2
Can anyone explain how to match the incident work notes values in Business rule to create a Parent/Child relationship.
MetricName: 'testing';
PodName: 'testing1';
Based on above these two values from work notes we need to create a parent/child relationship in Incident table.
Thank You!!
Hi @Tai Vu
I tried below code and its working only issue is when I run this code for new MetricName and PodName which is not present in Journal table than I am getting below screenshot error.
// Script for Location field
var grJournal = new GlideRecord('sys_journal_field');
grJournal.addQuery('element_id', current.sys_id);
grJournal.addEncodedQuery('nameSTARTSWITHincident^element=work_notes^valueLIKEPodName^valueLIKEMetricName');
grJournal.orderByDesc('sys_created_on');
grJournal.query();
if(grJournal.next()){
    var payload = grJournal.getValue('value');
// Regular expressions to match PodName and MetricName
   var podNameRegex = /"PodName"\s*:\s*"([^"]+)"/;
   var metricNameRegex = /"MetricName"\s*:\s*"([^"]+)"/;
// Extracting values using regex
   var podNameMatch = payload.match(podNameRegex);
   var metricNameMatch = payload.match(metricNameRegex);
   var a = podNameMatch ? podNameMatch[1] : null;
   var b = metricNameMatch ? metricNameMatch[1] : null;
   var grJournalsec = new GlideRecord('sys_journal_field');
    grJournalsec.addEncodedQuery('valueLIKE' + a + '^valueLIKE' + b);
    grJournalsec.addEncodedQuery('nameSTARTSWITHincident^element=work_notes');
    grJournalsec.orderBy('sys_created_on');
    grJournalsec.setLimit(1);
    grJournalsec.query();
    var syselid;
    if(grJournalsec.next()) {
    syselid = grJournalsec.element_id;
    gr.addQuery('sys_id', current.sys_id);
    if (gr.next()) {
        current.parent_incident = syselid; // updating child record
        current.update();
    else {
            current.update();
 })(current, previous);
In When to run condition I used after.
Thank You!!
